How to slip back Pro 2 micro USB cover that completely detached from body? (Potential Solution)
  • 0 Replies
  • 474 Views
  • 1 In Conversation
rugcan
Just discovered how to slip back an Arlo Pro 2 micro USB cover that completely detaches from the body.  Use a small jewelers flat screw driver to insert each side tab of the longtidudinal hole.  Once in (not completely) GENTLY peel  the round back edge side bottom rubber with the same flat head screw and the tab lack and tip will be exposed.  Slip it back - P.S. easier to handle if you do not insert the cover in the USB port while working it in.  Hope this helps.
0 REPLIES 0
  • 0 Replies
  • 475 Views
  • 1 In Conversation
