How does battery life on the Arlo Pro 2 compare to the Arlo Pro?
Excited to see an update already for the Arlo Pro. How does battery life on the Pro 2 compare with the Pro 1 series?
unfortunately I have to disagree. The battery life on arlo pro 2 is considerably worse than the arlo pro 1. I have 3 arlo pro 2s. coming from 3 arlo pro 1s. My arlo pro 1's would last around 5 months no problem. I havent been able to get 1 full month on the arlo pro 2's. Every camera, not just 1, it may be due to the bug it has where motion would last 10 seconds but the video will record for 5 minutes. Or maybe the bugged out night vision has something to do with it. But i have not seen good battery life from the arlo pro 2 at all.
5 minute recordings will kill the battery. You need to fix that first. What have you tried? Is all firmware up to date?
I've found the battery life on the Pro 2 to be pretty much comparable to the Pro. No noticeable difference that I've seen.
