How do you change the WiFi on the Arlo 2 camera? I tried doing it under the app however, there is nothing settings under WiFi network. I recently bought Google boosters and would like to swap the WiFi to get better connection on my cameras.
In simple terms, you can’t.
The cameras only sync to the base which has it’s own WiFi network( just for the cameras )
You can centrally locate the base for overall better signals to the cameras with the boosters ( if they have an Ethernet port ....or run multi bases ( the only true way to expand coverage area )
Ahhh! That’s crumby! Can you buy another arlo “base station” that is wireless that can connect to WiFi? I have 6 cameras and just two are getting really bad signals.
No, it's secure.
There's no "wireless" base but you can connect a base to a WiFi or powerline extender.
