How do I determine if my battery is bad or my solar panel is bad
  • 2 Replies
  • 954 Views
Clearymj
I have one Arlo Pro 2 camera with a solar panel that i recently attached to it.  Prior to attaching the solar panel I rarely had to charge it.  Now that the panel is attached and 'working' the battery does not last long at all, usually dies within a week or two.  All devices are less than a year old.  How do i determine if the battery is bad or solar panel is bad?
 just disconnect the solar panel and then fully charge battery... replace battery and see if the battery goes back to normal life usage
Clearymj
duh....Great point.  Thanks!
  • 2 Replies
  • 955 Views
