How can I setup local storage?
  • 2 Replies
  • 2191 Views
vishaljaitly
Hi,
I have two Arlo pro2 base stations (VMB3500r4) and was wondering how can I setup local storage for those?
The article bellow says it applies to VMB3500r4 and I can view videos saved on local storage but can you guide me how to set it up?
https://kb.arlo.com/1146850/How-do-I-view-videos-saved-on-a-local-storage-USB-device
Thanks in advance!
dcfox1
In addition, I would suggest the VMB4540 if you're looking at updating the base since this not only uses a USB drive but also allows you to use the app to see the local recordings without the need to unmount the drive for viewing on a computer.
  • 2 Replies
  • 2191 Views
