How Do I Adjust Motion Sensor Sensitivity?
  • 1 Reply
  • 5981 Views
Renoman1
How can I alter the motion sensors to reach a further distance
In the MODE,  go to the Mode you want to edit, hit ( on PC it's >, on ios it's pencil )  > to edit
pick camera then then edit
edit again if MOTION DETECTED and you will see a slide bar for sense level... higher is more sense
make sure you save on exit
Keep in mind that the cams (Arlo/Arlo Pro/Pro 2) will only detect people up to about 25 ft , tho they will detect cars at a longer distance as cars reflect IR ( which is how they detect motion )
So keep your coverage area less than the max range and eliminate roadways, then adjust your sense levels to what works for your location.
  • 1 Reply
  • 5982 Views
