- 2
I just installed a pair of these batteries, Amazon.com: FGGHOO Arlo Pro Battery 2-Pack [Upgrade] 3000mAh Replacement Battery Compatible with Arl..., and even after fully charging them the battery status for both cameras shows them at 32% charge. At that charge level they shouldn't last more than a month or two before needing recharging which would be disappointing to say the least. I'm wondering if this low charge level is actually related to the interaction of the batteries and the camera's firmware? Anyone have any knowledge of this issue?
The only way to solve this is to create negative PR
as of this morning.... Arlo PRO or PRO2 battery; New
https://www.amazon.com/Arlo-Accessory-Rechargeable-Battery-Compatible/dp/B01LYCMLY5
Where can I buy an authentic battery for an Arlo pro camera?
Not a copy cat type battery.
I bought two batteries from Amazon and they only lasted a few months.
I want the real thing.
battery
Arlo doesn't sell them any more since the product is so old (relatively speaking). I suppose you could buy some from a battery store that offers a warranty that you can access by walking into the store.
- 2
