Have 5 Arlo Pro Camera I constantly Have Issues With One Of Them - Located On The Exterior Garage.
One Arlo Pro camera frequently is not working. It continues to buffer - with exterior sounds intermittently - which tells me that is may not be consistently connected. Then it will frequently kick me out completely saying that it will not stream. Recently it started to alert about movement but nothing is in library (and it know there was movement because it was me). It also frequently will have major streaking with little to no detail or half of the picture will streak and the other half is fine. The other 4 units are fine. I have a wi-fi mesh system and everything works fine with the system to include smart lights, Ecobee HVAC, smart blinds and multiple Alexas. All that being said each issue is intermitten with good quality being infrequent and seems to be getting worse. It is very frustrating!! Any assistance would be greatly appreciated!!
How many bars of signal are you getting for that camera? It sounds like it's either too far away or subject to interference from your many other smart home devices. Can you switch the garage camera with one of the other cameras and see if you get the same experience?
