I just started getting a hardware limit reached message. I have 4 cameras. This is my only account. It's worked fine until recently. Seems like there's an issue with software.
Never heard of a hardware limit. Post a screenshot of the error message.
@MICHAEL2000 wrote:
I thought 5 was the limit without a subscription.
It is. Plus the system will let you add more than 5 cameras - you lose features (until you get a subscription), but the system will let you add them.
I've never seen this particular error, and there certainly are folks using your base with 4 or more cameras.
One thing you could try is removing all the cameras (and base) from your account. Then do a factory reset of the base, and add everything back. https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
