Hard drive + Alexa show
Also if you want to view a camera on a Alexa show unit , how long will the live stream stay on the screen for if the cameras mains powered , can it be viewed as long as you want or will Alexa time out ?
Thanks .
The cloud is required. You could set the system up including the USB drive and then disconnect it from the Internet but you would have no control or notifications.
Can't answernthe Alexa question.
Regarding viewing the camera on Alexa, it will show you the same viewing time on the Arlo app which is 30 minutes. After 30 minutes the viewing will be timed out and then you need to command alexa again to view the streaming.
Also if using a hard drive will it store 24/7 footage to the hard drive or just the motion detected video ?
No Arlo camera will record 24/7 - they're all motion-based. These would be stored locally. However, you can subscribe to the CVR option per camera which accomplishes the same thing but it will not be recorded locally - only in the cloud. You could record it locally after the fact by starting the replay and use screen capture software to record the important parts.
Again, the whole system is based on cloud services.
