  • 1380 Views
BIllyHoyle
Hi - I have the Arlo Pro 2 5-camera pack that came with the VMB4000 base station. I bought a 6th camera and would rather not pay $10/month to add it to my account as I don’t need any of the benefits that come with that. I saw that I could get another base station, pair the camera with that, and add it to my original account.
My question is - should I get another base station or a smart hub? The comparison the Arlo website doesn’t help as it shows literally the same features.
Thanks!
If you'll never buy a camera that requires a SmartHub, the base is fine. Depending on which hub you might get, I prefer one that allows a USB drive to be connected as opposed to the microSD card that the VMB5000 uses.
BIllyHoyle
Thanks! What does the SmartHub do that the base station doesn’t?
JessicaP
Hi BIllyHoyle,
You can read the differences here: What is the difference between each Arlo SmartHub and base station?
  • 1381 Views
