Geofencing with iPad & iPhone with same login
  • 2 Replies
  • 740 Views
N4KHQ
I just set up geofencing on my iPhone and the wife's iPhone. With limited testing it seems to work great. I noticed the web portal uses flash so I was thinking about the installing the Arlo app on the iPad but figured if I logged in with my password it would mess up geofencing, Is there a  good way to use the iPad just for viewing? Should I send the iPad a friend request, set up a new Arlo account and not select the iPad for geofencing? Only had the Pro 2 a couple of days but It appears to be the top product is security cameras from the research and my limited experence. Thanks
Yes.  That will let you use the iPad w/o forcing a log-out of the app (since only one logon is allowed for the account at a time).
N4KHQ
  • 2 Replies
  • 741 Views
