Free Arlo 7 day cloud storage + local storage
Is it possible to get both the free 7 day cloud storage and also record locally to a USB device (via a SmartHub or base station)? Or is it only one or the other?
Local storage should work for any camera connected to any VMB4xxx or VMB5000 base/hub. Use of the VMB4540 or 5000 allows you to view the recordings via the app while the older bases require you to eject the drive for viewing on a computer.
Only older cameras get the free 7-day cloud storage - Arlo stopped offering that on new camera models back in 2018 when they introduced the Ultra.
All cameras connected through a VMB4xxx or VMB5000 base will have their videos recorded locally. If you have the 7-day cloud storage or a paid subscription, then the videos are stored in parallel to the cloud.
If you get a smarthub (VMB4540 or VMB5000), then you can directly access the local recordings from the app. There are quite a few caveats, so post back if that is important to you.
If you have a different VMB4XXX base (VMB4000, VMB4500), then you need to eject the USB storage and connect it on a PC for viewing.
Though you didn't ask this - if you have some cameras with 7-day free storage and some without, then you can get single camera subscriptions for the ones without. If you have 3 or more of these cameras, it is cheaper to get the unlimited subscription.
