False alarm at the same time everyday
  • 2 Replies
  • 595 Views
Johnyeh
hi Arlo squad
For some reasons it’s disarmed from 3pm to 8pm of my time , but the camera still triggers the siren at exact 4pm if there’s a motion.
not 359pm or 401pm, only at 400pm, if there’s a motion detected, this happens to all the cameras at 400pm
Is there something I can do to fix this? The schedule is disarmed at that time and I’m using geofencing, all the devices are at home.
Does the behavior change if you disable geofencing?
Johnyeh
Hi Shephen
yes, it will switch back to the correct mode, basically only the random siren on while detected motion at 4pm
  • 2 Replies
  • 596 Views
