  • 2329 Views
autobackup
I would like to enable/disable 'Motion Detection' on dividual cameras rather than only globally.
This would be a useful enhancement of the Arlo Pro 2 capabilities
autobackup
Thanks guys for all your replies - however by the time I received them I had already managed to work out how to do it!!
The only comment I would make is that the menu tree sequence is not very easy to find or, for that matter, particularly intuitive!
- but once found it works!!
JessicaP
Hey @autobackup,
You can choose individual cameras to enable or disable motion detection by creating custom modes through the app or web.
You can also temporarily turn them off using the On/Off toggle in Settings, My Devices, your camera. If you need this on a repeatable schedule, the post above is a better solution. Read the FAQs here on modes and schedules.
autobackup
  • 2330 Views
