Does the cloud hold data past the 30 days?
I need to know, does the cloud hold data longer than 30 days. I have a week of data i need but it is longer than 30 days ago.
In the past if you upgraded to the higher level of 60 days you used to get back the missing days ...... But the last couple times have been tried they only got an extra 10 days so it may not work ..... but if it's worth it to you for one months payment ( you can sign up for one month ) then try it.
@TomMac Does arlo have access to cloud data further back than I can access.
As stated... maybe. I don't know how long the info stays in the servers... but with todays issues on privacy I would guess not more than the allowable of Elite level which is 60 days...
In the past it was possible if upgraded, but the last couple time NG.
Unless you get a subpoena, really unknown.
