- Email to a Friend
I am about to setup my camera for outside use and will be connecting to electrical power. Should I remove the batteries when connecting to electrical power
- Email to a Friend
It doesn't matter if the batteries are installed when running on power. Leaving them in allows the camera to continue to work during a power outage but you'd also need a UPS on your modem, router and base to make it useful.
Be aware that there's no official outdoor power supply for these cameras. There are aftermarket ones but you risk your warranty by using them.
- Email to a Friend
- Email to a Friend
- Email to a Friend
Don't forget that high humidity can cause condensation that can get into the power connection.
