Deleting videos
This doesn't make any sense, I have 2 4500 bases and the latest 4.5 app one main base I can delete all the recorded videos at once and the 2nd base I granted access to myself I can't I have to delete one at a time, on the older app I could delete all at once from both bases, why is it like this?
Sounds like a SW change.
Have you tried to sign in only directly to the second base and see if the full delete works?
@TomMac@JamesC@ Yes if I login to the 2nd shared base I can delete all at once. If iam logged into the main base (front of house) which I am always are then go to manage events I can delete all those videos at once if I go to the shared base (rear of house) it won't let you delete all at once have to do one at a time, old app use to let you delete all videos between main and shared.
