Sure would be nice to be able to select multiple recordings and delete them vs one at a time.
You can.
In the app, press on "select" in the upper right. Either press "select all" on the upper left, or touch the videos you want to delete. A box will be drawn around each selected video. Then press delete on the bottom right.
You do the same in the browser (using the mouse of course).
You can.
