Dead Base Stations
Hello I have recentry installed two base stations (VMB4000) with 5 cameras. Everything was fine but today I found both stations dead. No lights or anything. I tried to switch off/on the power supply but no luck. What has happened? why both at the same time? what do I have to do? Thank you
Check the power supplies or the outlets...it would be very odd to both going out at same time unless something like a power surge from lighting
