Délai d’enregistrement
- S'abonner au fil RSS
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Nouveau client, 1ère question.
Lors d’une détection de mouvement, la caméra Arlo Pro 2 n’enregistre que 10 secondes plus tard. Est-ce possible de modifier pour que l’enteg débute au moment de la détection ou même avant ?
Merci
- Étiquettes:
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
@YvesG2020 wrote:
Bonjour,
Merci
There is some recording lag, but 10 seconds is obviously too long. Try restarting the base and the camera (remove/reinsert battery) and see if that helps.
You can also try adjusting the camera position and the motion sensitivity, and see if that reduces it. Note that the camera is most sensitive to motion across the field of view. https://kb.arlo.com/000051462/How-do-I-position-my-Arlo-Pro-2-camera
If those don't help enough, then you can try support: https://www.arlo.com/en-us/support/contact.aspx
Note that if the cameras can be powered with the AC charger, then they will use a 3-second lookback - which also will help. Of course using AC power often isn't practical.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Bonjour @YvesG2020,
Si les manipulations proposées par StephenB ne change rien (la réinstallation de votre système, le changement du niveau de sensibilité et du positionnement), je vous conseille également de vérifier la vitesse de votre connexion à Internet sur cette page : https://www.speedtest.net/fr Quel est votre débit montant (upload) ?
Bonne journée,
Paula
Équipe Arlo
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Reset have been done, there is still a lag in the recording... maybe 10 secondes was exaggerated... i would say enough not to capture the movement from someone walking from sidewalk to door... approx 20 feet, the camera record when person enter the door.
Upload speed 27,6 Mbps
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Merci pour la réponse
Test est fait... 27,6 Mbps up et 36,3 down
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Bonjour @YvesG2020,
Merci pour votre réponse.
Un petit délai peut être normal, cependant il est toujours très utile d'analyser le fonctionnement de votre système avec notre support technique. Peut-être il serait possible d'améliorer la connexion et d'éviter le délai. Je vous invite donc à contacter mes collègues du support technique afin d'ouvrir un ticket d'incident. Mes collègues de la ligne française sont disponibles du lundi au vendredi de 9h à 17h30 sans interruption.
Bonne journée,
Paula
Équipe Arlo
80 -
Assistance et stockage
101 -
Avant d'acheter
Communauté Annonces
Géolocalisation
23 -
Notes de publication
- « Précédent
- Suivant »
