Continue to get notifications even after setting vehicles, people, and animals only
arlo pro2
What are the notifications listed as? "All other Motion" Do you have activity zones enabled?
i get "motion detected, etc."
I have tried various activity zones, but shadows activate the recording
Just to double check, do you have the "All other Motion" checked/ON?
Have you tried to remove the camera from the active list and re add it under Settings > Smart Notifications?
will try
