Contacting Technical Support
  • 4 Replies
  • 756 Views
QuantumDog46
A couple of questions about contacting Technical Support.
Tonight, I tried to contact Tech Support. There was an option to send them an email. I did so and was given a case number. It also told me that I could log into my.netgear.com to update the case any time. I tried to do that but my Arlo login wouldn't work. How can I log in and access my case if my login doesn't work?
Second, after submitting my first request, I tried to submit a second email. That option was gone and was replaced by an online Chat link. Has this happened to anyone else? How can we reliably get the email-to-support link?
After Arlo split from Netgear (it's still part of Netgear but a separate entity) there's no consumer connection between the two. WHat used to work no longer does, as you found. The only way I know of to check on the status is to reply to any email you received as a function of opening a case or by using chat or phone and referencing your case number.
The email option only exists when chat isn't available. There's also phone numbers to call.
QuantumDog46
Thank you. I did wonder if the appearance of the chat option was related to the time of day.
WiltshireUK
I have cancelled my subscription and the system saved my credit card - I cannot remove my card information. The company store my card information despite i want this to be removed. The company is breaking all the terms of the GDPR guideline.
Any help will be appreicated as i cannot find any support email address.
ShayneS
@WiltshireUK
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
  • 4 Replies
  • 757 Views
