Connectivity Arlo Pro 2 base VMB4500
  • 1 Reply
  • 1111 Views
Schleprock22537
Im using a Starlink router that is completely wireless. Ive tried connecting the Arlo base to my desktop with the ethernet cable with no success any suggestions?
I'm not surprised.  That won't work unless you have internet connection sharing set up correctly on the PC.
If there is no LAN port on the router, then you can get a wifi extender that has an ethernet port.  Then set up the extender to connect to the router, and connect the base to the extender's ethernet port.
  • 1 Reply
  • 1112 Views
