Compare Arlo and Arlo Pro2
  • 2 Replies
  • 2755 Views
lwachsman
Because I wanted to only spend a certain amount for a Christmas gift I purchased Arlo Wireless 3 pack at Walmart on Black Friday.  I am now second guessing my decision.  I myself have the 4 pack Arlo Pro2.  I was wondering what is the biggest diference in the two cameras AND also if the two are compatible?  I have a 4th camera I do not use that I could give to my son and his wife.
The Pro is sort of second gen, the Pro2 the 3rd.... Arlo being the first.
Major difference is the Arlo uses 4-123 sized batteries ( oem or rechargable ) and the Pro/Pro2 use a battery pack.
read these; ( esp click on the "+" sign for tech info )
https://www.arlo.com/en-us/products/arlo/default.aspx
https://www.arlo.com/en-us/products/arlo-pro-2/default.aspx
Last, all cameras and bases work with each other, you can mix and match
You can compare the cameras by using the Product link at the top here and then use the comparison chart.
All wireless cameras are compatible with all bases.
  • 2 Replies
  • 2756 Views
