Comparability with Model # VMV4500
  • 1 Reply
  • 1064 Views
Krichard65
Hi!
   I’d like to know which cameras are compatible to add with my model# VMB4500.
Im not 100%, but I believe I have the Arlo pro 2 if I’m not mistaken.
Any camera that can use a base is compatible
But all new cameras will require a paid subscription to get any cloud storage.
While your base does support local recording, it does not support playback.  The only way to see local recordings with your base is to eject the storage using the app, and connect the storage to a PC for viewing.
One way to tell is to open the camera housing and remove the battery.  You'll find a label there.
  • 1 Reply
  • 1065 Views
