Checking Hard drive remotely on Arlo Pro 2
Couple questions
1) Can I check the capacity for my Hard drive remotely with app
2) Will it rewrite over it's self once it has reach capacity
Thanks in advance
hitechtony wrote:
Couple questions
Thanks in advance
1) no..you must eject it
2) yes if that option is set ( you can toggle it on/off )
For the first question (checking capacity remotely), yes, use the app/browser and go to Settings, My Devices, your base, Local Storage and click on your drive. It shows the formatted capacity and available space.
