Cannot login/view live camera feed anymore. Gives "http failure response error".
I cannot log in to Arlo on my PC using Google Chrome anymore; it gives me a "http failure response" error. I can login using Internet Explorer, but cannot view live feed; the cameras all time out. This has been going on for at least a week.
Live feed is working for me - I'm using Windows 10, and Chrome 90.0.4430.72
Are you able to view recordings in the library?
Have you tried restarting the base?
On Internet Explorer, I can see all of the recordings in the library fine. I can see all the settings (and change them) fine. But no live feed on my PC. Can't even login using Chrome. Sorry, I'm not at home right now, so I can't re-start the base unit. However, it all works fine on my Android phone.
Hi ATC250R,
Try clearing your cache and cookies on your browser to see if that helps. And have you tried on incognito mode to see if you're able to view the camera live feed?
