Cannot customize camera settings for Away/Home modes
I have nine cameras on my system. Five older Pro 2s and an Essential Spotlight Camera on my old VMB4000 base station. I also have two Essential XLs on wifi, and an LTE Go2 on Verizon. When I upgraded to the new app last year, I was not impressed - still not - but I managed to set my system up as close to how it use to be as possible. Now I want to make some sensitivity changes and I can't figure out how to customize the camera settings in each mode.
The only thing I use modes for is changing the recording rules and motion sensitivity. I want the sensitivity on most of the camera to lower during the day, higher at night. It appears now that only the Go2 cellular enable camera has a "customize device" option available in the mode rules. There is a "default mode settings" for each camera in device setting, but that doesn't seem to be working to make changes for each mode. I loved the flexibility I used have. Not as good as it use to be.
You can do this 2 ways:
1) Use each camera's Default Mode Settings for one mode. For the other mode, each camera's rule, use Add an Action and choose Customize Device, choose the camera, Modify Settings, and change as desired.
2) For each mode and rule, use Customize Device.
