I just purchased arlo pro 2. When trying to get into mode using iOS, I do not have options, it just says “getting information”.... My friend has a arlo pro and is able to go to modes, and has pencil for editing...I don’t have that option at all.
I've had my Arlos for about 5 months now and have never run into this issue. When I go into my Arlo app there is no mode option to disarm or arm my cameras like there has been in the past. I have no extra users and I have already restarted my base station several times along with deleting and reinstalling the app. Any ideas? 🙂
Hi, I have the same problem as yours with my android device. I already contacted Arlo about this and was informed that they are really having issues with android devices wherein MODE option is not shown on the Arlo app. They said that their engineers are still looking on to it and will just give us an update once issue is already fixed.
For the meantime, I am using my pc or my ios phone in changing the MODE of my Arlo system.
Having exactly the same issue. Had the cameras for a couple of weeks, no issues, Arlo app update on 05.05.18, now no Mode tab on Android App (Running 7.0 3 build NRD90M) on Galaxy S7. In addition Geofencing is also not working. Location services on Android fully enabled and working in other apps. So effectiveley, I have to leave the house, then open the laptop attach wifi dongle while sitting in the car (around the corner so the camera isn't tripped when I leave home) to activate Armed as no Mode tab and no Geofencing on mobile. You pay a shed load of money for a system that is let down by appalling software apps. Come on Netgear, you've already had 4 days to sort this....!
I'm having the same problem with the Android Arlo App, version 2.5.1_21471, on the Pixel 2.
It's not acceptable to not be able to change modes. Why on earth even have cameras installed if I can't activate a mode? Frequently using a laptop to set modes is not an option for me, and if this is not fixed quickly, I'm going to abandon the Arlo system in favor of something that is more reliable.
Any help would be appreciated,
Cptbill,
Do you get this notification in the app & on the web portal?
Just ungraded from Arlo HD to Arlo Pro 2 (Both 5 camera set up).
Since upgrade Mode function not working via web app or ios App.
Please advise fix solution.
Note to support,
Mode is currently armed 8AM to 5PM will not allow me to modify, delete, change!
Just spent 1 hour with live chat support (Lyn) after a number of checks eventuallly factory reset the base station and now working fine.
Try a browser.
I am having the same issue.
Also one camera detects motion using the motions sensing test but will not record when test is turned off.
Attempted to change mode on laptop and changes are not saved and updated.
Just installed my system today and cannot access mode options. The rest of the system seems to work just fine, but i do not want to have to manually turn the cameras on and off every time I need to. Need the scheduling function. i did reboot the system a couple times to no avail. I have the problem on my IOS devices and computers using Firefox and Microsoft Edge.
I am having the same issue, tired chrome on mac and pc, safari, firefox ipad app. Cannot update the schedule or disarm the system. I upgraded the firmware on the cameras and the base station. Don't reall want to factory reset unless needed. Just bought the cameras today.
Arlo, worst ever. I had Swann for years never had this problem
Hope we get some answers!
						Arlo Mobile App629
						Arlo Pro 211
						Arlo Smart180
						Before You Buy995
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,322
