Can't schedule individual Pro 2 cameras, not showing in Mode option. Only showing Base Station.
  • 1 Reply
  • 739 Views
starman4000
I'm trying to schedule two cameras to shut off for a couple of hours while the sun shines toward them and is setting them off.  The instructions say to go to MODE to schedule a device, but the only thing showing in MODE is the base station and none of the five cameras.  Help?
Thank you!
First you need to make a custom mode for those 2 affected cameras....
add a mode; add first camera and then SAVE,  go back after and EDIT to add the second
Then go to MODE, click on the base icon and pick SCHEDULE and use the new mode
It is much easier in the web access over apps
  • 1 Reply
  • 740 Views
