Can’t get the app to sync to base
Can’t get the app to sync with my arlo 2. It’s brand new out of the box
Same problem. Arlo decided the Base staion was cactus so it's going back to be replaced eventualy.
Good luck dealing with ARLO support whether that be via phone or online chat.
If it's new, just swap at the store.
Why would you want to replace it with the same dead deal?
Huh?
