Can't Create A Rule That Includes A Siren Trigger
  • 3178 Views
Mameyson
I can't create a rule that includes a siren trigger.
When I edit a mode and then the rule says if motion or audio is detected then do the following.... I only get the option to record or do nothing. I don't get the option to trigger the siren.
Anyone experiencing that? I just bought the system, downloaded the most recent app and updated it.
Thanks for your help!
Did you try the Add Device selection when editing the rule?
Mameyson
What I noticed is that I can set it up only if I create a new custom mode. If I just choose the “armed” mode it won’t let me add the siren as a rule.
Just checked and the Armed mode indeed allows the addition of the siren to a rule. You can't set a rule for the siren itself but as an additional device (Add Device as mentioned above) to a rule for a camera.
  • 3179 Views
