Can not connect with new app
  • 1 Reply
  • 579 Views
LNC
I have the Pro2 1080p camera and audio doorbell. I downloaded new app and it will not connect. I have checked base and it is all green light. I have rebooted both stations and still will not connect. Any suggestions?
Check that you still do see all your devices via the web client (https://my.arlo.com in a PC)
If they are present, then try uninstalling the app, and installing it again.
If that doesn't work, then I suggest contacting support:  https://www.arlo.com/en-us/support/contact.aspx
  • 1 Reply
  • 580 Views
