I lost the charger for my Arlo Pro 2 and need to replace it. The $15 charger here looks correct, but they don't list any detailed specs on the product page. Is this model QC2.0 so it will actually charge the battery while running as opposed to simply powering the camera?
@flibbidyfloo wrote:
Will a QC3.0 certified charger also work? Like the Anker Quick Charge 3.0 39W Dual USB Wall Charger?
It should (QC 3 is compatible with both QC 2 and QC 1). But it's not something I've checked.
It's the right model for the Pro 2, and supports 5 v @ 1.8 amp and 9 v @ 1.1 amp.
Thanks!
Just an update - the Anker seems to work great - charged the used Arlo Pro 2 that I bought pretty quickly.
Thanks!
