Can I have the Arlo Pro 2 Cameras connect to the Google Wifi AP's
  • 1 Reply
  • 2205 Views
HamsonBears
Can I have the Arlo Pro 2 Cameras connect to the Google Wifi AP's vs the Arlo rounter? Signal is much better when on LAN WiFi. I have Arlo Rounter plugged into the Google Mian WiFi AP but it doesnt see it as a device on LAN.
If not, how far can I put camera from Arlo router?
Thank you for your help.
The Arlo/Pro/Pro2 cameras ONLY connect to the base.
The max distance is based on what the signal must travel thru ( listed at 300ft max line of sight ) so it's hard to say how far for you.
Either locate the base for a good signal for all cameras, use a wifi extender with ehternet port to move the base to a better location or use more than one base ( the only real way to expand coverage )( no limit on any account  for bases )
  • 1 Reply
  • 2206 Views
