whay is the best way to extend my camera range. I am thinking about powerline adapters..what kind are the best to use...I am thinking about puting base in a garage 150 feet awat on same power...
While WiFi / power line extenders do work, they still need an Ethernet port for the base...
You may be better served with just running Ethernet cable with a second base.
( only true way to expand area is with multi bases )
