Cameras turned dark at night
- Email to a Friend
My problem, 1 month ago, One camera went very dark at night when recording then all 3 went dark the next week, so bad I can't see what is happening, I can hear the noise. I have take out battery and resinked. I have turned night off and on. Uninstalled app etc.
What can I do now?
I am considering get a new camera and it won't be an arlo....
- Email to a Friend
It sounds like nightvision is no longer kicking in (or perhaps the IR spotlights are blocked or have failed). Can you try walking up to the camera at night while illuminating your face (with a flashlight, or with a flashlight app on your smartphone)? If you see color, then nightvision isn't engaging.
Does this happen with every single night recording, or is it occasional? Does it also happen when you livestream?
- Email to a Friend
It would be good if you could revert back to when the "NIGHT/DAY vision" could be adjusted while watching live.
Changing the vision the way you have it now is hopeless, as you have to turn off the vision then go into SETTING, change the vision, then go back into LIVE VISON. This can't be done in less than a minute and you still might choose the wrong setting as you have 5 choices. If an intruder is present, (s)he'll be gone by the time you have the correct setting.
Please revert back to previous set-up as explained.
- Email to a Friend
Not sure who you are talking to - no one on this thread works for Arlo. You could post this suggestion in the idea exchange (though maybe wait and see if the mods move it there).
- Email to a Friend
Hi Guru, If I turn on my flood lights it videos okay. it does activte in the day too. And films in color with the flood lights too so....I will do a restart live and also in the settings too and I will see......
- Email to a Friend
Thanks Steve, I will have a go doing what you have suggested. I have a friend who has arlo too and he is having the same problem.
- Email to a Friend
I thought this was `Arlo ` set up forum, but good to know. This is great as I have had a good response.
a huge thanks and I will let you know if I can get them working!!
