Cameras/Base go offline for no reason
Sadly this appears to be a recurring problem to which there is no lasting fix. Google the issue and you'll find several discussion threads regarding the same problem - many tagged "Solved"...
I've had the system for two years, the maximum time it has stayed online was probably a month or so. I performed a factory reset & resync (this is what the user guide tells you to do when everything else fails) a week ago and my base station just went offline again last night.
This is not an internet problem as all the three lights are green and wifi/internet access works fine otherwise.
It is a really frustrating bug as the resync requires you to bring all the cameras to the base station - plenty of time spent climbing on ladders. And obviously there is nothing you can do if you happen to be away from home when the problem occurs.
It would be great to hear from Arlo if this is a known problem, and if there is any other fix apart from constantly resetting and resyncing the base station and cameras?
