can anyone help because my camera 1 of 4 stopped taking night pics it records but all dark and hardly can see at night.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
What camera model is this?
Is NightVision turned on?
I took it out and reput it in. It still does not do night vision, Yes it is on. Thanks any info will be helpful
Do you mean you removed and reinserted the battery? Or something else?
Is this new behavior (was nightvision working with this camera in this location before)?
Yes I did take the whole camera off and the battery and restarted it again, the night vision is on and it always worked here for over 1 year. I cannot get it to start again. Any help will be appreciated.
Also check the camera settings for video brightness is set to zero or above.
I will try. Also the brightness was on almost full high now i put it at 0. I am not sure it will help but I will try.
Yes I see all the red lights. 4 are bigger than the 4 smaller in the miiddle
If you have a subscription you can contact arlo support for further advice.
I dont know what you mean switching. The camera is turned on to night all the time. It always worked at night before. I will try though to call arlo. Thanks for your help
If you enable nightvision, the camera will detect when it's dark enough to need it. If there's enough light, it won't use it.
Thanks so much for your help. This week end i will call in and see what they can do. It still does not light at all at night. Pure black. Fine during the day.
Set it back (try the brightest setting, which is 2).
Yes it is new. It always worked before. Ihave tried everything i can think of. It was taken out and reinstalled. The night vision is on. Any thing else please let me know
