Camera started a buzzing noise on all 4 cameras?
  • 1 Reply
  • 1101 Views
Elbyak07
Buzzing noise started around a week ago. The buzzing noise is happening in all 4 cameras. There’s no way all of them just got the same problem. I can’t contact customer support because I don’t have a subscription. I saw that cameras got a new firmware around the same time the issue started. Please help, cameras getting triggered for no reason.
You don't need a subscription to contact support - use the Contact Support link at the bottom here. Try rebooting your base to see if that helps. If not, a system reset may be the best and quickest solution, assuming it's not faulty hardware.
  • 1 Reply
  • 1102 Views
