Camera showing wrong view. Pointed down to driveway but showing pointing straight up?
  • 2 Replies
  • 1818 Views
Marcachusetts
I have a really weird issue. I logged into my cameras and the one that is pointed down the driveway is showing as pointing straight up the side of the house it is mounted to. I went to physically check the camera and it is still pointed down the driveway. I’m going to resync it in the morning but curious if this has happened to anyone else before.
dcfox1
Just to clarify is this a new install or just started happening?
Guessing your talking about a STATIC shot from camera...
It can happen if it was in that position when a recording happened and then moved back.
I would first reboot the base and if that doesn't fix it, then pull battery from camera and replace ( should auto resync )
  • 2 Replies
  • 1819 Views
