Camera require arlo charger
My cameras stopped charging past 20 percent because I’m not plugged into an Arlo charger, but I never received and Arlo charger with my cameras. They used to charge fine. Has this happened to anyone else? Do I have to buy a charger from Arlo now to use my cameras? Thanks
The Pro 2 cameras just require a charger that provides 5 volts at 2 amps. Most chargers should work.
Mebbe I'm getting old (I am) but I thought I remembered the Pro 2 NOT needing 9v to charge. However, since the batteries are the same...
Good catch!
