Camera only shows black & white and does not record movement unless object is within a few feet
  • 1300 Views
Sikorskidp
Camera shows only black and white video. Even live, in broad daylight. It also records no movement unless the object is within a few feet.
JessicaP
Hi Sikorskidp,
Try to clean the camera lens and sensor to see if that helps. Otherwise, try to remove the battery off from your Arlo camera completely and re-insert them back in.
Sikorskidp
That did not work. I am also now encountering a new problem. Both my outdoor cameras are connected to a solar panel. Both have worked fine for over a year. Now one camera gives me the message, Power source not compatable, and the camera battery drains in a matter of days.
  • 1301 Views
