Hello everyone! One of my cameras keeps going offline. And now it is flashing blue and orange lights. I tried syncing it and charging the battery. Nothing happens. Any help is appreciated.
Hi mackmv,
If your Arlo Pro 2 camera is flashing orange and blue LED lights, this means your camera is going through a firmware update and you should not turn off the camera. You can read about what you should know about firmware updates on Arlo camera: What do I need to know about Arlo camera firmware updates?
If your camera is still having problems and the firmware is not updating, you may need to remove the camera from your account and re-add it back on.
I've sent arlo a message on Facebook and still no help.
Hi Jmgjan1,
When you tried doing manual update, were you receiving an error? Have you tried removing the battery from your Arlo camera and/or reboot your Base Station to see if that helps?
Try referring to this article if your Arlo camera won't sync with your Base Station: My Arlo camera will not sync with my SmartHub or base station; how can I troubleshoot it?
If you still have problems, do let me know.
If you're still having problems, don't hesitate to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
