Camera Video settings Reset After Charging
Somthing I've noticed over the last few days, everytime I change the batteries/recharge a camera the video settings seem to revert to 'Best Battery Life" and not stay on the previous setting of either "Best Video" or "Optimized" when the camera comes back on-line.
I haven't noticed that but have seen it when using a browser to check/set that setting. I would then use the app to set it. Another user said it worked just the opposite for him. Try it both ways to see what works for you.
Thanks, I'll try checking via the WEB, next time.
So far I used the app (Android) everytime, as 9 times out of 10, I then used the app to check the camera positioning.
