Activer les suggestions
La fonction de suggestion automatique permet d'affiner rapidement votre recherche en suggérant des correspondances possibles au fur et à mesure de la frappe.
Affichage des résultats de
Camera Not Working
Répondre
Options du sujet
- S'abonner au fil RSS
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We have the Arlo Pro 2, came with 4 cameras. Three of the cameras are outside and are working great. The fourth camera has been inside and is no longer working. It won't charge, so I'm assuming the battery is no longer any good. We've only had the system not quite a year. I've been looking for a phone number to call customer service with no luck. The number I did call, I was hung up on six times and was told I would receive a call back so a replacement battery could be sent, which no call back ever happen.
Any suggestions?
1 RÉPONSE 1
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Have you tried to use a battery from the other cameras to see if those will charge? This will help isolate the issue to the camera, battery or charger. I have provided the link for Arlo Tech Support below.
Étiquettes
7 jours enregistrement Arlo pro 2
Apple TV
application
251 -
Arlo Base Station
Assistance et stockage
303 -
Avant d'acheter
222 -
Communauté Annonces
enregistrement 7 jours
Géolocalisation
61 -
Modes et règles
ne trouve pas
Notes de publication
13 -
Problème
VMB 4000
VMC4060
- « Précédent
- Suivant »
