Bought Arlo Pro 2 system. Don't have Ethernet to plug into... Any way to be stand alone system?
Hi, I just bought the system for my RV. I do not have an Ethernet to plug into. Do I need to return this to the store? Thx Susan
The system is built on a cloud service, so it does need an internet connection. Personally I'd return it.
You could look at the Arlo Go camera - it uses a cellular data connection, so you do need to pay for that. But it works doesn't need ethernet or wifi.
