  • 4 Replies
  • 2069 Views
KOB006
It seems to be difficult to connect 6 cams to the Arlo 2 Pro.
I bought 2 full set with base, (1x2 cam & 1x4 cam) however I can’t seem to find the right subscription that allows me to use 6 can at the same time.
Any one who can guide me?
Kind regards
Kasper
@KOB006 wrote:
Do you know which paid level I should update to?
I can’t seem to find the correct one
Premier would be the right level.  You'd get the 5-license subscription, and then add a single camera license to get the 6th camera.  Note the single camera license is half the usual price when combined with the 5-license plan.
https://kb.arlo.com/88/What-are-the-available-Arlo-subscription-plans-and-how-much-cloud-recording-i...
Note your cameras are only 1080p, so the 2K recording in Premier doesn't apply to you.  However, it still is the appropriate plan, since there are no 1080p only plans at the moment.  Elite will of course work too, but since you can't do 4K recording you'd be paying more with no benefit.
you can upgrade your basic account to a paid level and get all cameras on one account
OR
You can open two accounts ( diff pw/email ) and then share the second account to the first ( grant access )
KOB006
Thanks TomMac
KOB006
Thanks I have now updated with your recommendation and all 6 cams are working
  • 4 Replies
  • 2070 Views
