Blurry Arlo Pro2
I have Pro 2 arlo cameras, both are hard wired and have a good signal. Now when I sign in both cameras are blurry. When I go live the picture clears right up. I have restarted equipment and sometimes it clears up but next day blurry again. It's not my signal, so what causes this.
Sounds like you got a new version of the app which is causing this, at least for Android. The quickest way to resolve this is to go to Feed and then back to Dashboard or Devices which should then be clear.
It's a known problem.
I tried that and it didn't work. My picture is still blurry. Both my cameras are doing the same thing. When I go live it will clear up after going to a black screen first.
Wait for an app update that should fix this. In the meantime, yes, it's a pain.
